visual editor problems with images
Brogan
Is this on a default installation with no template edits or add-ons?
If not, what changes have you made to the templates?
Is the editor .png file in the correct styles directory?
It should be: styles/default/xenforo/editor/icons.png
Looks to me as if it's missing.
u're right
in defaut stile it's all works
Brogan
Copy the image from the default style to the style you're using.
Do a comparison on all the directories as it's possible you're missing others too.
There have been a few new and changed images since the first beta release.
