Duplicate  Style / cookie problem
Marcel
Forgive the layman/non-technical explanation here.
I have my style set to 'Kitchen Sink', which is fixed width.
When I return back to the site after a while (what I'm presuming is the cookie / logout timeout).
Upon first load it loads the full width style....then reverts back to my fixed with choice after a few seconds (presumably when the page has fully loaded).
Not really a bug per se, more of a bugbear / annoyance. A layman's view would be that the forum is applying my chosen style last....
Mike
I'm presuming you registered via FB? If so, then that is down to how FB handles auth. We can't know that you're a FB user until you've loaded a page.
Marcel
That would explain it.
But IIRC I'm a bone fide 100% registered forum user. I added the Facebook auth afterwards.
Mike
Yeah, it's basically applicable if you login via FB. Strictly speaking, there's nothing we can do to prevent it, but we can try to make the experience better (let you know what it's doing). There is another bug here that related to when FB was half down that covered that, so I'm going to tag this as duplicate.
Thanks for the report. :)
