XF 1.5 A cookie problem (?) with two XenForos
We have two XenForo forums. They are under the same domain, but in different folders. Like this:
http://domain.com/forum1 (old forum, XenForo 1.4.8)
and
http://domain.com/forum2 (new forum, XenForo 1.5.4)
They have mostly different users, but some of us use both forums, at least me as an admin. I have a unsolved configuration problem, which I suppose might be cookie-related. I'd like to get an easily understandable guide how to configure the forums to avoid the occurred problem.
The problem:
If I login the old forum and then login also to the new one, the old forum kicks me out instantly. Vice versa, the same behavior if I try to login old forum when I am already logged to the new one.
Chris D
You need to set a different cookie prefix for one or both sites.
e.g. add to config.php:
$config['cookie']['prefix'] = '15x_';
Thanks!
I'll try that.
EDIT: Now it's OK. If someone other has the same problem, the Config.php options are explained in this list.
