M Mart456 Member Nov 18, 2017 #1 Hi I just upgraded to XF 2, the layout is appears to a little messed up, is there an easy way to reset everything and load the defuat style. (mine appears to be missing the expected default style thanks)
Chris D XenForo developer Staff member Nov 18, 2017 #2 If it’s what I suspect it is then you just need to switch off the “Minify CSS” option in CloudFlare. This is actually a bug in the CloudFlare minifier. Upvote 0 Downvote
M Mart456 Member Nov 18, 2017 #3 Chris D said: If it’s what I suspect it is then you just need to switch off the “Minify CSS” option in CloudFlare. This is actually a bug in the CloudFlare minifier. Click to expand... Thats that worked - turned off minfify and cleared the cache, and now working, thank you Upvote 0 Downvote
