lightspeed
- Affected version
- v2.2.7 Patch 1
If you have "Send reports into forum" set, and then delete that forum, the "Send reports into forum" shows up as "None". The problem is that moderators will not be able to see the Reports link under the Moderator Tools anymore even though "Send reports into forum" shows up as "None".
To get the Reports showing up under Moderator Tools again, you have to select another forum under "Send reports into forum", save it, then set it back to "None" again and save it again.
I thought no one was reporting on my forum anymore, however it turned out that my reports center link had been hidden for a number of years!
How to reproduce:
1. Go to Options -> User discouragement and discipline -> Send reports into forum
2. Select a forum
3. Go to Forums > Nodes and Delete the forum you selected above
4. Go to your forum home logged in as a moderator and the Reports link under Moderator Tools will be gone.
5. Go back to Options -> User discouragement and discipline -> Send reports into forum and it will be set as "None"
How to reproduce:
2. Select a forum
