Please help me get an If Then statement correct to block tabs for Guests
Jamie
I have the shoutbox installed and since guests can't use it I would like to just hide the tab for anyone that can't use it.
So what is the code I am looking for?
<if guest>
Show Guest menu
<else />
Show Member menu
</if>
Thanks!
Jamie
Jamie
Figured it out.. In case anyone else is wondering, here is an example I was playing around with to see if it worked.
For Guest, the home tab is called Continue and for Members it's called Home.. I know, silly but it was a quick exercise to see how it worked. :)
<xen:if is="{$visitor.user_id}">
<li class="navTab home PopupClosed"><a href="{$homeLink}" class="navLink">{xen:phrase continue}</a></li>
<xen:else />
<li class="navTab home PopupClosed"><a href="{$homeLink}" class="navLink">{xen:phrase home}</a></li>
</xen:if>
<xen:else />
</xen:if>
Based on that description I think you got the condition reversed. The first block is true for logged in users. The second block is true for guests.
Jamie
Oh.. i thought this line: <xen:if is="{$visitor.user_id}"> was saying if this user IS a visitor... no?
Jamie
/learning curve here.. :)
Well, you are accessing the $visitor[] array, but you are specifically checking the user_id. Only logged in users have user_ids.
The direct condition to check for guests is:
<xen:if is="!{$visitor.user_id}">
	FOR GUESTS
</xen:if>
This reads, "if the user does not have a user_id."
Jamie
Ah, ok. Thanks for your help! btw, how did you wrap that in the blue code tag? I looked but couldn't see a BBcode tag for that and ended up with smiles in my example. :)
Jamie
Jeremy P
That condition will determine if the person currently visiting the page has a user id, which only logged in users would.. so yes it is reversed.
EDIT: Ahh too late.
[code]
CODE STUFF HERE
[/code]
edit - Jeremy wins ;)
