So ask him to revert to his "tested" setup. Once is set the way they like, they cannot complain if things are broken, right? In my humble opinion, your host setup is a disaster, but that is just me. Once everything is reverted to their likings, start looking at the logs and point them the issues. I expect they will not provide with any support and blame it on XenForo software, which we all know it works perfectly fine in an minimal CentOS environment.In my case, my host came back and said that he has got a specific "perfect" and tested setup, and from the moment we start messing with it (example changing the hanlder to support APC), he cannot support me and I have to do everything by myself.
Just to make things clear: a minimal setup is better because 1) it uses a lot less resources and 2) allows you to identify a lot easier the problems since you don't deal with intermediate parts that could affect/break your server stability.
Ultimately, that might be the best solution.So, basically he's saying he won't support anything other than his default setup (which doesn't work...) so I'll change hosts.
