XF 1.2 xen:helper snippet problem
Biarritz64
Hi,
i have a little problem with helper snippet
{xen:helper snippet, $thread.lastPostInfo.user_id, 1}
return "1..." instead of "1" only.
How to remove "..."
Thank you
@Brogan
For this, i want to had last poster avatar in xenportal,
i use this code to get the avatar
<xen:set var="$avatarGroup">
{xen:if '{$thread.lastPostInfo.user_id} < 1000', '0', '{xen:helper snippet, $thread.lastPostInfo.user_id, 1}'}
{xen:if '{$thread.lastPostInfo.user_id} > 9999', '{xen:helper snippet, $thread.lastPostInfo.user_id, 2}'}
</xen:set>
<img src="data/avatars/s/{$avatarGroup}/{$thread.lastPostInfo.user_id}.jpg" alt="{$thread.lastPostInfo.username}" />
My problem is that {avatargroup} return "1..." or "2..." i want to remove "..."
Thank for your help
