DragonByte Tech
- Affected version
 - 2.0.0 XF.Com Edition
Yeah, so I don't have any screen recording software just now so bear with me.
Step 1: Post a post using a smiley.
Step 2: Edit the post
Step 3: Attempt to type an uppercase letter directly before the smiley, I tested it with Shift-B
Step 4: Notice a small overlay window appears underneath the smiley, and you can't enter text anymore
I posted this post: https://xenforo.com/community/threads/tickets-paid.104308/page-13#post-1175830 and noticed I had typed
I went to edit the post, I placed the indicator directly to the left of the smiley, and began typing
EDIT: The overlay window has icons for Replace, Remove and Add Link, and can be brought up by clicking the smiley while editing. If you edit this post and try to add an uppercase letter after the " in Step 3, you will see the bug. Lower-case letters do not trigger this behaviour, so it leads me to believe it's related to the Shift key.
EDIT 2: Further testing shows the issue has nothing to do with the " character, I've amended the report accordingly.
Fillip
as they don't need attention in the same way a![]()
"Bug" but when I tried to type the uppercase B, the small overlay window appeared.EDIT: The overlay window has icons for Replace, Remove and Add Link, and can be brought up by clicking the smiley while editing. If you edit this post and try to add an uppercase letter after the " in Step 3, you will see the bug. Lower-case letters do not trigger this behaviour, so it leads me to believe it's related to the Shift key.
Fillip
