XF 2.1 Theme house products not work in XF 2.1
No you cannot downgrade unless you restore from a backup.
We can't provide support with add-on issues though, you will need to discuss the issues with the authors.
FYI, be sure to check for each add-on (in that case you need to contact ThemeHouse) if it's compatible with new XF version because XF 2.1 is a significant upgrade. And of course, never run Beta versions on a production forum otherwise you just take a risk.
It will be a while until we have our product line fully compatible with XenForo 2.1, as many of our product require significant large-scale changes. We don't recommend upgrading to 2.1. with our add-ons or styles active at the moment.
Any help to exit from "The site is currently being upgraded. Please check back later." mode.
@adnanbcn once you have things running again there are several XF backup options you’ll find floating around. Personally, I use the 8WR database backup by @Jaxel and have had no problems with it. You can backup both locally and/or to a free amazon account - it also backs up your database and entire forums paths/files.
I think Chris D also has a solution. Either way, trust me - having been in your shoes before - automated backups are a lifesaver.
Good luck!
same error "The site is currently being upgraded. Please check back later." i just find a 4 month old backup, i see in my server config the backups, and yes i have a backend system, but in pause for remote capacity problem :( so i go back 4 month :(
