Problem with embedding images from Xenforo into vBulletin
Garamond
When trying to embed images into a vBulletin forum that are uploaded into an XF forum, it doesn't show.
What sorcery is this?
I like how Xenforo is different in many ways, but come on :( there is something called useful changes, and this aint it.
/rant
mrGTB
Strange one, I also tried to do same before and couldn't. There doesn't seem to be an extension like jpg. Well there is, but then you get numbers coming after it, such as viewing your avatar. Because it doesn't end with JPG, instead numbers after it. Doesn't get displayed on another forum if you try using IMG tags.
Good in one way because it helps stop hotlinking, but odd none the less how it works. I don't understand it either.
http://xenforo.com/community/data/avatars/l/6/6128.jpg?1319479656
James
The numbers correspond to the UNIX timestamp of when you uploaded the avatar. It'll change next time you upload one.
It prevents your browser cache from showing the cached image instead of the real one when you update and shouldn't affect images, but if it does just remove the question mark and the following numbers, it'll do no harm.
Garamond
It does not help removing the question mark/last numbers :( I've tried that several times, and I'm getting somewhat annoyed by the way Xenforo handles image attachments.
