Radhi
Peace be upon you Yesterday the forum around us from vb to xf
After conversion we upgraded the forum from xf 1 to xf 2.0.1
However, the extension through the Google engine all turn into this link
https://www.--------.com/vb/install/index.php
Means installation path
Is there a solution?
However, the conversion files 301config.php and the following are still available in the forum forum
The conversion has been implemented with the first generation, and the extension has been properly developed, but with the upgrade, the archiving has changed.
