Hello,
when trying to do the upgrade, I get the following message:
If I knew under which user the upgrade is run, I could easily do a chown to fix it. But I do not know it - adding the user name to the message would be an improvement (at least from my point of view). Maybe there are cracks out there who know it by heart, but that's not the case with me.
The following issue was found when determining if a one-click upgrade is possible: The files are owned by a different user than the upgrade is running as.
