Robby Well-known member Feb 19, 2018 #1 After upgrading to xenforo 2 evrything was ok. When i upgraded resource manager i get this: navigation error. How can i fix this?
Ozzy47 Well-known member Feb 19, 2018 #2 Does the same thing happen on a unmodified default style? Upvote 0 Downvote
Robby Well-known member Feb 19, 2018 #3 i had the same on my testforum and that was ok. I just replaced the default style, was ok but then i put the resource manager on and get this nav problems. Upvote 0 Downvote
Ozzy47 Well-known member Feb 19, 2018 #4 Go to /install and click the button to rebuild the master data. That should rebuild the phrases. Upvote 0 Downvote
Robby Well-known member Feb 19, 2018 #5 ozzy47 said: Go to /install and click the button to rebuild the master data. That should rebuild the phrases. Click to expand... That worked. Thank you very much. You have been real helpfull! Upvote 0 Downvote
