My first add-on, need some help [ERRORS]
Heavy
Hey, now is the time to make my first add-on, and I'm almost done.
However, when I install it on my forum, I get a few errors.
Would anyone like to help me fix this? :)
Thank you!
Errors I get:
Regards,
Heavy
Have you tried installing it not using the add-on installer just using stock Xenforo? Probably will make no difference as the error is probably telling enough.
Did you write your XML file by hand or did you actually export the XML from your devboard?
I exported a add-on i got by a friend (IRL)
And then i was going to edit it, but doen't seem to work?
