Guys, you urgently need something to do with tabs. Is not the first situation where the tabs just do not fit in width. And it's not always possible to reduce the translated version.
I might try to do something with the IP address floating tab, but otherwise allowing tabs to wrap is as designed. Though some changes made today that make that a little more obvious.
