max #nodes/#forums and Page width controller
#1
xenForo is truly great stuff. I have a demo running and plan to integrate part of the node/forum into an existing review site. users will be able to access the forums directly or through an existing 'read reviews' page which has 580px width available.
I want a liquid width with min.width of 580px, I set these parms:
min-width: 580px;
_width: auto;
_margin: 0 auto;
but the min.width seems stuck at ~980px, any advice?
Also, because of the integration with a review site with many review objects/threads, what is the max #nodes and #forums?
Thanks.
Rob
Max nodes and forums I should think is unlimited. xenForo is designed to be completely scalable and I should think that would apply to the depth of it's hierarchy. As for the display / style issues I simply cannot comment yet as Im just starting out customising styles
Mike
#3
XF is designed with 1024x768 as a minimum. The min width is likely on the html element so you can remove that, though I suspect you're going to run into a lot of design issues trying to fit the whole thing in that width.
