XF 1.5 Exif orientation problems
Fred.
Hi,
I'm having issues with exif rotation when I upload images with Xenforo. (1.5.14 and also with 2.0.0 DP9)
When I upload the same images with my ftp client the orientation is perfect.
I use Imagemagick but I tried both GD and Imagemagick and they both rotate wrong.
Could this be a setting in PHP?
I'm trying to troubleshoot this but I don't know where to look anymore. I already updated Imagemagick.
The same Images work perfect here and on the XF2 test forum.
Here are the test images
https://github.com/recurser/exif-orientation-examples
You may not have the exif extension enabled. Check phpinfo and see if you can see mention of "exif" anywhere. If not, that functionality will need to be enabled.
