Easier way to amend same occurrence in many templates?
arms
I want to amend:
{xen:helper threadPrefix, $content}{$content.title}
To
{xen:helper threadPrefix, $content}{xen:helper threadPrefix2, $content}{$content.title}
Is there a better way than many template modifications?
Would it be possible to amend the default threadPrefix helper?
You would effectively be overwriting the helper, I haven't looked at the code but you could start with something like:
public static function helperThreadPrefix($arg1, $arg2)
    $prefix1 = XenForo_Template_Helper_Core::helperThreadPrefix($arg1, $arg2);
    $prefix2 = self::helperThreadPrefix2($arg1, $arg2);
    return $prefix1 . $prefix2;
public static function helperThreadPrefix2($arg1, $arg2)
    // threadPrefix2 code here.
    return '';
So, with that set up, you probably don't need to modify any templates.
