robi052
I have .htaccess with force redirect non www to www. Today I change TLD (domain is old, only TLD) and try force redurect visitors and spiders from www.domain.in to www.domain.com but do something wrong and now cannot access to board. I forced to www.www.domain.com/forum. (Browser issue)
Old domain: hedonist385.in
New domain: hedonist385.com
XenForo path: /home/user/public_html/forum
Here is htaccess. I want force nonwww to www and from domain.in to domain.com and want inform Google to new domain (to prevent double posts).
EDIT
I think problem resolved. Forget add [OR] in second line. Now is htaccess (It's OK now?) How Google see that redirect?
# Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
#<IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
#</IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 500 default
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{HTTP_HOST} ^hedonist385\.in$
RewriteRule ^(.*)$ http://www.hedonist385.in/forum/$1 [R=301,L]
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
#RewriteBase /xenforo
# This line may be needed to enable WebDAV editing with PHP as a CGI.
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.*$ - [NC,L]
RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml|robots\.txt) - [NC,L]
</IfModule>
EDIT
#</IfModule>
RewriteEngine On
RewriteCond %{HTTP_HOST} ^hedonist385.in$ [OR]
RewriteCond %{HTTP_HOST} ^www.hedonist385.in$ [OR]
RewriteCond %{HTTP_HOST} ^hedonist385\.com$
RewriteRule ^(.*)$ http://www.hedonist385.com/forum/$1 [R=301,L]
</IfModule>
