XF 1.2 Customize header problem
#1
Hi,
Would like to have in the top off my header my logo that is 100% width and 90px hight
and under i would like to had a banner (center position)
i did not find any solution, all the times, it makes the navbar moves and it hide a part of the bord
Any help will be very appreciate
Thank you
Xenforo version 1.2.3
default template
Frederic
Brogan
#2
You will need to increase the height of the header area to the total height of your logo and banner combined.
#3
thanks for your answer
how can i do that? i try to change "Height of Header Logo" and "Header Tab Height" it dosn't work
Edit: I find the solution
THank you
Shelley
THank you
I'd wait till @Brogan pops on to dismiss/confirm but I'm sure you would need to add the increased height (height of the banner in your case) to the #headerMover #headerProxy
So lets say your banner is 60px in height you would add 60px on top of what you have already to the #headerMover #headerProxy height value.
