Fixed Ctrl-X or right-click cut do not work in editor
Xon
Affected version
2.0
On initially loading a thread, select some text and then Ctrl-X or right-click cut do not work in editor.
Toggling from bbcode mode off & on appears to workaround the issue.
I can reliably reproduce this issue with Chrome 63 on Linux. I suspect this issue occurs whenever there is a line break.
Type the following into an empty textarea and then try to cut one of the two words:
Test
Test
Multiple lines is the key.
It's actually down to a Froala bug which has been fixed, though we may not have access to that version until it is released. We may be rolling back to an earlier version.
We've rolled out the in-development version of Froala that has a fix for this here. If there are situations where you can still reproduce it, please let us know.
