XF 2.0 Strange adsense problem
brattanek
I'm just after upgrade to XF 2. After implementing adsense codes ads I perform tests and:
- mobile ads work in all pages
- desktop ads don't work only in home page (works in other sites)
Code was pasted in Container breadcrumb (top): Above
<div align="center">
<div id="google-ads-1"></div>
<script type="text/javascript">
    /* Calculate the width of available ad space */
    ad = document.getElementById('google-ads-1');
    if (ad.getBoundingClientRect().width) {
        adWidth = ad.getBoundingClientRect().width; // for modern browsers
    } else {
        adWidth = ad.offsetWidth; // for old IE
    /* Replace ca-pub-XXX with your AdSense Publisher ID */
    google_ad_client = "ca-pub-xxxx";
    /* Replace 1234567890 with the AdSense Ad Slot ID */
    google_ad_slot = "xxxxx";
    /* Do not change anything after this line */
    if ( adWidth >= 728 )
      google_ad_size = ["750", "200"];  /* Leaderboard 728x90 */
    else if ( adWidth >= 468 )
      google_ad_size = ["468", "60"];  /* Banner (468 x 60) */
    else if ( adWidth >= 336 )
      google_ad_size = ["336", "280"]; /* Large Rectangle (336 x 280) */
    else if ( adWidth >= 300 )
      google_ad_size = ["300", "250"]; /* Medium Rectangle (300 x 250) */
    else if ( adWidth >= 250 )
      google_ad_size = ["250", "250"]; /* Square (250 x 250) */
    else if ( adWidth >= 200 )
      google_ad_size = ["200", "200"]; /* Small Square (200 x 200) */
    else if ( adWidth >= 180 )
      google_ad_size = ["180", "150"]; /* Small Rectangle (180 x 150) */
    else
      google_ad_size = ["125", "125"]; /* Button (125 x 125) */
    document.write (
     '<ins class="adsbygoogle" style="display:inline-block;width:'
      + google_ad_size[0] + 'px;height:'
      + google_ad_size[1] + 'px" data-ad-client="'
      + google_ad_client + '" data-ad-slot="'
      + google_ad_slot + '"></ins>'
    (adsbygoogle = window.adsbygoogle || []).push({});
</script>
</div>
i change code for standard one and is the same. The same situation is with ad in sidebar widget.
Any idea why ads not shown in desktop home page? Google block?
can you give me example?
You can even use inline css as suggested by adsense.
https://support.google.com/adsense/answer/6307124?hl=en&ref_topic=3641113
<style>
.example_responsive_1 { width: 320px; height: 100px; }
@media(min-width: 500px) { .example_responsive_1 { width: 468px; height: 60px; } }
@media(min-width: 800px) { .example_responsive_1 { width: 728px; height: 90px; } }
</style>
<script async src="//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script>
<!-- example_responsive_1 -->
<ins class="adsbygoogle example_responsive_1"
     style="display:inline-block"
     data-ad-client="ca-pub-XXXXXXX11XXX9"
     data-ad-slot="8XXXXX1"></ins>
<script>
</script>
This is what Adsense gives you in their control panel for responsive ad units:
     style="display:block"
     data-ad-client="ca-pub-xxxxxxxxxxxxxxxx"
     data-ad-slot="xxxxxxxxxx"
     data-ad-format="auto"
     data-full-width-responsive="true"></ins>
<script>
</script>
What I do is create css media rules in the extra template (this example has three sizes):
.top_ad
	background-color: rgb(245, 245, 255); max-width: 320px; min-width: 320px; width: 320px; max-height: 100px; min-height: 50px; display: block; margin: auto; text-align: center;
.top_ad_container
	background-color: rgb(245, 245, 255); max-width: 100%; min-width: 320px; width: 100%; max-height: 100px; min-height: 50px; display: inline-block;  margin: auto; text-align: center;
@media(min-width: 600px)
	.top_ad
		max-width: 468px; min-width: 468xpx; width: 468px; max-height: 60px; min-height: 60px; height: 60px;
	.top_ad_container
		min-width: 468px; max-height: 60px; min-height: 60px; height: 60px;
@media(min-width: 1100px)
	.top_ad
		max-width: 100%; min-width: 728px; max-height: 90px; min-height: 90px; height: 90px;
	.top_ad_container
Then in the template where the ad should go:
<div class="top_ad_container">
	<div class="top_ad">
Adsense code goes here
	</div>
</div>
The reason I use two DIV's is I've found if done with only one, some browsers no matter what I put in the CSS rules Adsense will left align the ad. Auto-margins, text-align: center, etc. have no effect. Not all the ads, but occasionally. The outer DIV I use is defined as an inline block, the inner as a block.
