remove help from Navbar into footer / move username from to help-position
erich37
I am wondering how to remove the "Help" section from the Navbar and put it into the footer.
Then putting the Username (which is the drop-down at the top-right) into the position where we have the Help-section.
I am wondering how this would look like and whether this would give a better understanding for the user to navigate XenForo ?
I think having the "Help"-Tab is not so important to have it prominently sitting in the Navbar.....
yeah, but as you see not even experienced coders manage to properly remove the Help-Tab from the Nav-bar, so I do not want to bother for hours.... just to achieve simple changes.
Major changes to the navigation (Completely changing its look from default), will take many hours to get things to work properly.
