XF 2.1 Problem with icons
Ultim-Host
New member
Hello, I'm currently testing a theme before putting it on my forum, but on all the themes I've used, no FontAwesome is displayed, as you can see here :
I tried on the theme Innovate Dark and it's the same, no FontAwesome
My configuration:
Php 7.2
Xenforo 2.1.2
Xenforo Resource Manager 2.1.2
French for @SyTry ;)
Oui mais comment on sait quelle version on utilise, je ne sais meme pas quelle version c'est et si c'est installé??
English version:
Yes, but how do we know which version we are using?
English version:
Can you give me the code you have in your screen ? In XenForo 2.1 you need to use the Font Awesome 5.5+
Can you provide a link to the site where it's not working?
Most likely there will be something in the browser console which should help to identify the cause (possibly server related).
