Problem after clicking on "Begin Installation"
Hello, after I am clicking the "Begin Installation" Button, the next error appears:
"You cannot proceed unless all XenForo database tables are removed."
What should I do?
Thanks.
JVCode
Are you using WAMP server on localhost? if so, all of us are having the same problem. I propose using xampp.
Kuma
If you are using IE9 try throwing IE8 compatablity mode (F12 then switch the render mode to IE8 standards) after emptying the database.
nestor718
What should I do?
Thanks.
Restart the install from here:
<xenForo>/install/index.php?install
It should then give you the option to use the same config and drop the original data/tables.
