Have you tried creating a new style - based on the default (1.1.4) - to see if that cures the problem? (It should at least let you know if it's a template issue)
How do the actual usergroup permissions look?
Is the permission still set as it was before the upgrade?
okay this might be part of the issue. I have 500 records in my user table but it is only showing 2 total users for the count on the user's admin page.
hhmmm....
Any idea on what would of caused this?
NM... This was a user error on my end. The software/upgrade worked just fine. Completely my mistake...
Don't mess with the user_status column in the user table.
I may use xenforo as a model on how to develop other sites and I am sure I modified the xenforo database when I meant to modify my 3rd party site database.
