Need a little htaccess help
AdamD
Hi all, need a little help with my xenforo htaccess file.
I have the standard Xenforo htaccess file, but I also added a section to redirect NON www visits, to the WWW url, but for some reason, it just isn't kicking in.
# Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
#<IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
#</IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 500 default
RewriteEngine On
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
#RewriteBase /xenforo
# This line may be needed to enable WebDAV editing with PHP as a CGI.
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.*$ - [NC,L]
RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml|robots\.txt) - [NC,L]
RewriteCond % ^findahost.biz [NC]
RewriteRule ^(.*)$ http://www.findahost.biz/$1 [L,R=301]
If you visit - http://findahost.biz
Does it redirect you to the www variant? or stay as non www?
If I click Home, it goes to the WWW site, but clicking "forums", and it remains at the non www site.
My forum details are all set to the full WWW url, so I'm confused.
RewriteCond %{HTTP_HOST} ^domain.com$ [NC]
RewriteRule ^(.*)$ http://www.domain.com/$1 [R=301,L]
Add your custom rewrite before the XenForo stuff and after RewriteRngine On
So
#</IfModule>
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteCond %{HTTP_HOST} !^www\.findahost\.biz$
    RewriteRule ^(.*)$ http://www.findahost.biz/$1 [R=301,L]
</IfModule>
