XF 2.3 importing from IPB4 to Xenforo stuck need help
ice5192
I am not able to get the importer past this step.
I have tried everything i know to get it to work
using the trailing slash etc.
/home/therealm/public_html/uploads
etc keeps saying does not contain the expected contents.
I am importing from my Invision Power Board 4
I am using a subdomain.mydomain.com
Do i need to move my Xenforo to my root?
You should put the full path to the directory containing the uploads directory, so if your uploads directory is at /home/therealm/public_html/uploads then the Invision root directory would be /home/therealm/public_html
That worked thank you! looks like all my permissions on my nodes are messed up. Is there a quick way to make it so the noeds all show as the admin im seeing this
