Princ3 Member Feb 20, 2014 #1 I think the title explains itself. I want to have my new created threads on the results of google.
P Paul B XenForo moderator Staff member Feb 20, 2014 #2 If the forum is closed to guests then it is closed to bots. Bots are guests. Upvote 0 Downvote
Jeremy in memoriam 1991-2020 Feb 20, 2014 #3 This is also penalized by Google and other search engines. Upvote 0 Downvote
Princ3 Member Feb 20, 2014 #4 When my forum was using Mybb I could give the search engines the access to threads even when it was closed. Upvote 0 Downvote
DBA Well-known member Feb 20, 2014 #5 Princ3 said: When my forum was using Mybb I could give the search engines the access to threads even when it was closed. Click to expand... You sure that that wasn't the Google Adsense bot? Upvote 0 Downvote
P Paul B XenForo moderator Staff member Feb 20, 2014 #6 Princ3 said: When my forum was using Mybb I could give the search engines the access to threads even when it was closed. Click to expand... Google classes that as cloaking. Cloaking is considered a violation of Google’s Webmaster Guidelinesbecause it provides our users with different results than they expected. Click to expand... https://support.google.com/webmasters/answer/66355?hl=en Upvote 0 Downvote
Princ3 Member Feb 20, 2014 #7 DBA said: You sure that that wasn't the Google Adsense bot? Click to expand... Not sure but is it possible to do with the google adsense? What are the benefits of it? Is it possible to remove threads from public view instead of the whole node? Thank you for the answers I really appreciate! Upvote 0 Downvote
DBA Well-known member Feb 20, 2014 #8 Princ3 said: Not sure but is it possible to do with the google adsense? What are the benefits of it? Is it possible to remove threads from public view instead of the whole node? Thank you for the answers I really appreciate! Click to expand... Giving access to the Adsense bot doesn't have anything to do with Google Search though, it's only to help target your ads in non public pages. Upvote 0 Downvote
