Editor Fonts - Additional WYSIWYG Fonts
Editor Fonts - Additional WYSIWYG Fonts 1.0.6
latropa
latropa submitted a new resource:
Editor Fonts - Additional WYSIWYG Fonts - Adds self-hosted fonts to XenForo's rich-text editor.
Editor Fonts is a lightweight XenForo 2.3 add-on that includes six additional font families and lets administrators choose which of them are added to XenForo's existing rich-text editor Font family menu.
The fonts are bundled directly with the add-on and served locally by your XenForo installation. No third-party font service or CDN is contacted when visitors view your site.
Included fonts
  • Anton
  • Comic Neue
  • Great Vibes
  • Grenze Gotisch...
latropa updated Editor Fonts - Additional WYSIWYG Fonts with a new update entry:
1.0.4 - File Health Check Hash Fix
Fixed: Corrected package hashes for the bundled WOFF2 files so they no longer produce false “Unexpected contents” warnings in XenForo's File Health Check. No functional changes to the editor or font behavior.
XQ Editor Fonts Changelog
Version 1.0.4
Fixed
  • Rebuilt hashes.json using XenForo-compatible SHA-256 hashing behavior so the six bundled WOFF2 files no longer produce false "Unexpected contents" File health check warnings.
  • No...
Quick Q, I use Anton on my page titles and within page nodes. But I do reference it externally.
Will this font addon allow me to not have to do that?
1.0.5 - Eight New Fonts Added
Version 1.0.5
Added
  • Added eight bundled font families: Aldrich, Bitcount Single Ink, Black Ops One, Bowlby One SC, Isometra, Lobster Two, Press Start 2P, and Slackey.
  • Added a 1.0.5 upgrade step so upgrades copy the expanded fourteen-font bundle into data/xq-editor-fonts/.
  • Added the GNU GPL v2.0 license text for the bundled Isometra file and expanded the font license map.
Changed
  • Fresh installations now select only Anton, Comic Neue, JetBrains...
Yes. It should for Anton. If you are doing something like this for the page titles:
CSS:
@import url('https://fonts.googleapis.com/css2?family=Anton&display=swap');
.p-title-value,
.node-title
    font-family: 'Anton', sans-serif;
With this add-on installed, It could be changed to:
CSS:
.p-title-value,
.node-title
  • Like
Reactions: CTS
Add an addon, ... delete a manual template edit.
Perfect and works as hoped.
Tnx
1.0.6 - External Data Storage Support
Version 1.0.6
Changed
  • Replaced direct local public-data filesystem writes with XenForo's abstracted data:// filesystem and XF\Util\File helpers.
  • Font installation and upgrade now copy all fourteen bundled WOFF2 files to data://xq-editor-fonts/ so the active XenForo data adapter determines the physical destination.
  • Global @font-face URLs are now based on a URL resolved in PHP with XenForo's applyExternalDataUrl() helper and supplied to PAGE_CONTAINER through a...
