XF 1.4 Database settings problem on installation
Artisan
New member
I am trying to install XenForo 1.4.7 for the first time and I'm seeing the following error:
The following error occurred while connecting to the database:
Access denied for user 'cl53-forum-pi5 '@'10.0.44.116' (using password: YES)
I've checked with the hosting support and they have confirmed that the settings are correct - "The database name will be the same as the username. Your MySQL Databases are hosted on the respective servers listed on port 3306". Using 'localhost' is OK as I have used it with other applications in the past.
Any ideas? I'm a XenForo newbie!
Username and password are definitely correct - both copied/pasted with no additional line breaks/characters picked up while copying. Do the rights have to be set up in phpMyAdmin or in one XenForo's files?
I've never had this problem with any other installation before on the same hosting service.
