No twitter integration for the login, Sheldon?
I can add it. Give me just a bit. Generally don't get a lot registered that way, but hey, I don't mind getting on it.
---- Should be turned on now.
Site keeps going offline for me. Can't access it again.
Cheers Sheldon, I'll have to register when I get on the PC tomorrow though. I keep getting an error from my mobile.
You have a lot of talent Sheldon. I did get a few database errors through the day but other than that, I like the simplicity of the forums and the work done to the design.
Thanks, appreciate that.
The main goal has been to keep it light and simple, all while still providing depth if that is what you are looking for. As for the errors, not sure. I do play around on a live site a bit much... likely too much... haha. If they arise again, if you catch it let me know, I will definitely look into it.
Was on my phone. Will get you the error next time. Should show up in the error log though on admin.php I would think.
I'm pretty sure I've had an account on like all of your sites, and I'll continue to do so. You got a great mind on you, brother.
