BoyG
I'm receiving a report that the xf_search_index table of the xfdb database has crashed.
I'm trying to repair it via phpmyadmin but have been unsuccessful.
It is currently marked in use in phpmyadmin and when I try to repair it it gives me an error.
Here is the text of the Check Table command I got.
CHECK TABLE
xfdb.xf_search_index check warning Table is marked as crashed and last repair failed
xfdb.xf_search_index check warning 1 client is using or hasn't closed the table prope...
xfdb.xf_search_index check warning Size of indexfile is: 2431643648 Should be: 1...
xfdb.xf_search_index check error Can't read indexpage from filepos: -1
xfdb.xf_search_index check Error Incorrect key file for table './xfdb/xf_searc...
xfdb.xf_search_index check error Corrupt
I'm having the host take a look at it also but is there anything I can do on my part to fix this?
Thanks in advance for the help.
CHECK TABLE
xf_search_indexxfdb.xf_search_index check warning Table is marked as crashed and last repair failed
