3rd AnGle
What kind of a sick error is this? I don't know if this caused the problem..We moved from one server to another.. and had imported the sql dump.
Template Errors: thread_view
- Illegal string offset 'thumbnailUrl' in /home2/hippy/public_html/mbbbbnnnns.com/library/XenForo/Template/Abstract.php(265) : eval()'d code, line 2015:
2014: <li id="' . (($__compilerVar73) ? ('AttachedFileTemplate') : ('attachment' . htmlspecialchars($__compilerVar74['attachment_id']))) . '"
2015: class="AttachedFile ' . (($__compilerVar74['thumbnailUrl']) ? ('AttachedImage') : ('')) . ' secondaryContent">
2016:- Illegal string offset 'thumbnailUrl' in /home2/hippy/public_html/mddfffffks.com/library/XenForo/Template/Abstract.php(265) : eval()'d code, line 2019:
2018: ';
2019: if ($__compilerVar74['thumbnailUrl'])
2020: {- Illegal string offset 'filename' in /home2/hippy/public_html/mdddsssks.com/library/XenForo/Template/Abstract.php(265) : eval()'d code, line 2034:
2033: $__compilerVar75 .= '
2034: <!--<img src="' . XenForo_Template_Helper_Core::styleProperty('imagePath') . '/xenforo/widgets/page.png" alt="' . htmlspecialchars($__compilerVar74['filename']) . '" />-->
2035: <span class="genericAttachment"></span>- Illegal string offset 'filename' in /home2/hippy/public_html/manrrrrssks.com/library/XenForo/Template/Abstract.php(265) : eval()'d code, line 2042:
2041: <div class="AttachmentText">
2042: <div class="Filename"><a href="' . XenForo_Template_Helper_Core::link('attachments', $__compilerVar74, array()) . '" target="_blank">' . htmlspecialchars($__compilerVar74['filename']) . '</a></div>
2043:
