Using xenforo post parser outside xenforo?
Member 3639
Okay so i am looking into the post parser at the moment.
After including the file how do i run my own text through it? For example loading a post outside the forum and parsing it? Which functions do i need to pass it through?
Indigo
Assuming you already have the XenForo_* classes available (via autoloading setup - see index.php/admin.php for examples in bootstrapping).
$formatter = XenForo_BbCode_Formatter_Base::create();
$parser = new XenForo_BbCode_Parser($formatter);
$html = $parser->render($text);
Member 3639
It's odd in a test.php file i have this:
<?php
$startTime = microtime(true);
$xenforoRoot = '/home/prxainf1/public_html/gamingonlinux.info/chill';
require($xenforoRoot. '/library/XenForo/Autoloader.php');
XenForo_Autoloader::getInstance()->setupAutoloader($xenforoRoot . '/library');
XenForo_Application::initialize($xenforoRoot . '/library', $xenforoRoot);
XenForo_Application::set('page_start_time', $startTime);
$text = "[b]test[/b]";
echo $html;
Which works fine, but when i put the main parts into a header.php file for my main site i get an unexpected error message crop up with no other details.
Indigo
Can you enable error reporting in that file to get a better description of the issue? Are you trying to integrate it with an existing software?
