Using xenforo post parser outside xenforo?
Member 3639
Is there a way to use the xenforo post parser outside of the forum?
I am integrating it here:
http://www.gamingonlinux.info/
So for the news posts i wish to use the xenforo parser as that's where the posts come from.
Was a bit tricky exporting my custom news database into the xenforo forum but i got it to work whipping together a quick a dirty php script to export my own news and then create threads/posts in the forum heh.
Just need to sort out the comments then it's done, so proud of myself lol.
I think you want this file:
library/XenForo/BbCode/Parser.php
This class has functions to parse BB code.
If you need help with the actual implementation then I suggest posting in this forum.
F
Floris
Guest
Shouldn't the library for xenforo have a bbcode dir with a Parser.php file in it? I am sure that one will have bunch of functions
[edit] Jake beat me to it.
