D DrWicked Member Oct 29, 2019 #1 Good Morning Community, i've a problem with this login that i've found when i've transfered the upload folder in localhost to my webhosting with FileZil4, i've added the data login of XenForo but it not still work, thanks of all, Enrico
J jeb35 Well-known member Oct 29, 2019 #2 You need to enter your login info from your own forum, not from Xenforo. Upvote 0 Downvote
J jeb35 Well-known member Oct 30, 2019 #4 Can you login to ACP? It could be addon related. Have you tried reuploading the upgrade package and choose to overwrite files when needed? Upvote 0 Downvote
D DrWicked Member Oct 30, 2019 #5 Yes Sir, the login to ACP in localhost work perfectly, I didn't do any upgrade for XenForo 2 and I've only one add on which is XenPorta Upvote 0 Downvote
