Unable to extend both Model_Post and ControllerPublic_Post
AndyB
I have successfully extended the Model_Post::canEditPost and here is the code:
<?php
class Andy_CanEditPost_Model_Post extends XFCP_Andy_CanEditPost_Model_Post
    public function canEditPost(array $post, array $thread, array $forum, &$errorPhraseKey = '', array $nodePermissions = null, array $viewingUser = null)
        // get parent
        $parent = parent::canEditPost($post, $thread, $forum, $errorPhraseKey, $nodePermissions, $viewingUser);
        if (!$parent)
            $this->standardizeViewingUserReference($viewingUser);
            if ($viewingUser['user_id'] == 5528 AND $post['post_id'] == 1894195)
                $parent = true;
        // return parent
        return $parent;
However if I also try to extend the ControllerPublic_Post, I get an error. Here's the code:
<?php
class Andy_CanEditPost_ControllerPublic_Post extends XFCP_Andy_CanEditPost_ControllerPublic_Post
    public function actionTest()
        // if not a super admin, return
        if (!XenForo_Visitor::getInstance()->isSuperAdmin())
            return;
The error I get is this:
Fatal error: Cannot redeclare class XFCP_Andy_CanEditPost_Model_Post in /home/southbay/www/forums/library/XenForo/Application.php(513) : eval()'d code on line 1
You either have two files somewhere in any of your directories which have the same class, e.g. class Andy_CanEditPost_Model_Post extends XFCP_Andy_CanEditPost_Model_Post
Or your code event listener for that add-on load_class_model doesn't have an event hint.
If you don't have an event hint (in this case presumably it should be XenForo_Model_Post) then in your Listener you should be doing something like:
if ($class == 'XenForo_Model_Post')
    $extend[] = 'Andy_CanEditPost_Model_Post';
Event hints and/or that conditional will prevent your extended class from being applied more than once.
