The largest database on the server my forum is on is the xenForo database at 600MB. I've run MySQLTuner and these are the results, I think it's set up well enough but not really too sure. Any pointers would be appreciated.
-------- General Statistics --------------------------------------------------
[--] Skipped version check for MySQLTuner script
[OK] Currently running supported MySQL version 5.5.32-cll
[OK] Operating on 64-bit architecture
-------- Storage Engine Statistics -------------------------------------------
[--] Status: +Archive -BDB -Federated +InnoDB -ISAM -NDBCluster
[--] Data in MyISAM tables: 451M (Tables: 1129)
[--] Data in InnoDB tables: 819M (Tables: 1840)
[--] Data in PERFORMANCE_SCHEMA tables: 0B (Tables: 17)
[--] Data in MEMORY tables: 745K (Tables: 29)
[!!] Total fragmented tables: 183
-------- Performance Metrics -------------------------------------------------
[--] Up for: 33d 21h 28m 26s (74M q [25.533 qps], 3M conn, TX: 3873B, RX: 30B)
[--] Reads / Writes: 59% / 41%
[--] Total buffers: 1.3G global + 3.6M per thread (5000 max threads)
[OK] Maximum possible memory usage: 19.0G (81% of installed RAM)
[OK] Slow queries: 1% (1M/74M)
[OK] Highest usage of available connections: 1% (95/5000)
[OK] Key buffer size / total MyISAM indexes: 8.0M/91.7M
[OK] Key buffer hit rate: 99.9% (356M cached / 417K reads)
[OK] Query cache efficiency: 83.2% (47M cached / 56M selects)
[!!] Query cache prunes per day: 4033
[OK] Sorts requiring temporary tables: 0% (4K temp sorts / 952K sorts)
[!!] Joins performed without indexes: 423115
[!!] Temporary tables created on disk: 39% (736K on disk / 1M total)
[OK] Thread cache hit rate: 99% (95 created / 3M connections)
[!!] Table cache hit rate: 18% (3K open / 17K opened)
[OK] Open file limit used: 16% (2K/14K)
[OK] Table locks acquired immediately: 99% (25M immediate / 25M locks)
[OK] InnoDB data size / buffer pool: 819.5M/1.0G
-------- Recommendations -----------------------------------------------------
General recommendations:
Run OPTIMIZE TABLE to defragment tables for better performance
Increasing the query_cache size over 128M may reduce performance
Adjust your join queries to always utilize indexes
When making adjustments, make tmp_table_size/max_heap_table_size equal
Reduce your SELECT DISTINCT queries without LIMIT clauses
Increase table_cache gradually to avoid file descriptor limits
Variables to adjust:
query_cache_size (> 256M) [see warning above]
join_buffer_size (> 1.0M, or always use indexes with joins)
tmp_table_size (> 192M)
max_heap_table_size (> 24M)
table_cache (> 524288)
