N nassella Active member Aug 8, 2016 #1 Is it possible to get a search engine that provides results for both our Xenforo Forum and the blogs on our Wordpress site?
Paul B XenForo moderator Staff member Aug 8, 2016 #2 You would need a custom solution for that, otherwise you can always use Google search and embed it into the site. Upvote 0 Downvote
N nassella Active member Aug 8, 2016 #3 Brogan said: You would need a custom solution for that, otherwise you can always use Google search and embed it into the site. Click to expand... As always thanks for the quick reply Upvote 0 Downvote
