jeetkune
I'm facing a problem that I don't know exactly what is causing this problem that is causing me to blame a lot of people unfairly.
Several people who don't even know each other on the same ip address seem to be using the same ip address on the forum. When I click on the more users button, it shows up.
Let me tell you before you ask. I do not use Cloudflare
https://xenforo.com/community/threads/ip-address-bug-more-users-issue.203472/ I also tested what is described here and the problem persists.
I asked users to google and send me screenshots of their ip addresses. The ip addresses are correct. Xenforo shows ip addresses correctly but sometimes it seems to add some users together as if they are using the same ip address.
In the admin panel, in the seo optimizations section, an option to ananomize ip addresses for google analystic is active. Could this option cause this?
