XF 1.2 Problem with Width
Matthew Hawley
So on my laptop the pageContent aligns up with the search bar.
But on someone elses computer it doesnt.
The width is 1041px
If I put the pageWidth back it will look like this.
Put pageWidth back and then modify your header background image. Use the gray and black background bars from your navTabs and tabLinks and put them on the bottom of the image. Set the height of the bg image to the same as the header. If aligned correctly the header background will line up with the backgrounds of navTabs and tabLinks seamlessly.
