XF 2.1 page node prevent p-body
AcidCat
Ok so whatever content I put in a page currently gets wrapped within p-body > p-body-inner > p-body-main > p-body-content > p-body-pageContent
I need it so my raw html is outputed instead.
Current output is:
HTML:
<div class="p-body">
    <div class="p-body-inner">
            <div class="p-body-header">
                    <div class="p-title ">
                            <h1 class="p-title-value">Home</h1>
                            <div class="p-title-pageAction">
        <a href="/index.php?pages/front/bookmark" class="bookmarkLink button button--link " title="" data-xf-click="bookmark-click" data-label=".js-bookmarkText" data-sk-bookmarked="addClass:is-bookmarked, Edit bookmark" data-sk-bookmarkremoved="removeClass:is-bookmarked, Add bookmark"><span class="js-bookmarkText ">Add bookmark</span></a>
</div>
                    </div>
            </div>
        <div class="p-body-main  ">
            <div class="p-body-content">
                <div class="p-body-pageContent">
test
<div class="blockMessage blockMessage--none">
</div>
</div>
            </div>
        </div>
    </div>
</div>
I just need it to output "test"
Example:
CSS:
.column {
  float: left;
/* Left column */
.column.leftside {
  width: 25%;
/* Middle column */
.column.middle {
  width: 50%;
/* Right column */
.column.rightside {
  width: 25%;
/* Responsive layout - breakpoint at 800pixels */
@media screen and (max-width: 800px) {
  .column.side, .column.middle {
    width: 100%;
You can change the width if you want. Put this code in extra.less.
The raw html:
HTML:
<div class="row">
  <div class="column leftside">
    <h2>LEFT</h2>
    <p>Left Sidebar</p>
  </div>
    <div class="column middle">
    <h2>Main Content</h2>
    <p>This is the main container</p>
    </div>
    <div class="column rightside">
    <h2>RIGHT</h2>
    <p>Right Sidebar</p>
  </div>
</div>
If you want a specific width for the sidebars you can use the calc function in css.
Example:
Leftsidebar = 300 pixels
Rightsidebar = 300 pixels
___ +
Total sidebars = 600 pixels (important to know to use the calc function)
Width middle column = 100% - 600 pixels
The css code:
CSS:
.column {
  float: left;
/* Left column */
.column.leftside {
  width: 300px;
/* Middle column */
.column.middle {
  width: calc(100% - 600px);
/* Right column */
.column.rightside {
  width: 300px;
/* Responsive layout - makes the three columns stack on top of each other instead of next to each other */
    width: 100%;
Now you can set a specified width for the sidebars.
Example:
___ +
The css code:
CSS:
.column {
  float: left;
/* Left column */
.column.leftside {
  width: 300px;
/* Middle column */
.column.middle {
/* Right column */
.column.rightside {
  width: 300px;
    width: 100%;
this works perfectly, thanks!
That's not what was asked for, but if it's what you wanted.... Great!
It provides the same result regardless so its fine
