Why do you not use this feature in the style?
But so you should ask this question in the support thread on the add on you use for thexample grid style.
Nope, if you split it into two columns and have an even number of forums they should display at the same height. If you have an odd number the last forum will take up the full width (depending on your options) Pretty much everything is configurable
