XF 1.5 Need Help with Conditional
howarde
Hi.
I'm working on a conditional, with two parts, and they both work as individual conditionals, but when I join them, it's not working.
Here's what I want to do. If the user is in a group, and has their custom field set to "NO" then... else.
<xen:if is="{$visitor.customFields.display_ads_for_supportin} == 'no' AND !{xen:helper ismemberof, $visitor, 58}">
Do Stuff and block ads
<xen:else />
Do stuff with ads
</xen:if>
Thanks.
How have you set up the custom user field?
If it is a checkbox, the syntax would be:
<xen:if is="!{$visitor.customFields.display_ads_for_supportin} AND {xen:helper ismemberof, $visitor, 58}">
It's actually a select field, it takes "Yes" or "No" In hindsight, it probably should have been a checkbox, but I didn't set it up. It's been there a long time.
