A Alex L. Member May 14, 2021 #1 Need help for forums avatar. Hello community! How can I forbid users to upload their own forum avatars? I would like to use an avatar image for every user! Is that possible? Many thanks for the help!
Brogan XenForo moderator Staff member May 14, 2021 #2 It's a user group permission. If you want to set an avatar for each member, you can do so in the ACP. Upvote 0 Downvote
M MisakiTaro Well-known member May 14, 2021 #3 If you mean default one, you can change from ACP IRC. Upvote 0 Downvote
A Alex L. Member May 15, 2021 #4 Thanks for the answer. Where can I set a default avatar for each user? So that every user has the same avatar. Upvote 0 Downvote
M MisakiTaro Well-known member May 15, 2021 #5 You should set a Default Avatar image for every style. Upvote 0 Downvote
A Alex L. Member May 15, 2021 #6 MisakiTaro said: You should set a Default Avatar image for every style. View attachment 251960 Click to expand... Hello. When I use the Text to Image settings and upload an image, it doesn't show up in the forum. Upvote 0 Downvote
M MisakiTaro Well-known member May 15, 2021 #7 Alex L. said: Hello. When I use the Text to Image settings and upload an image, it doesn't show up in the forum. Click to expand... It could be only for new registers, the members that already registered may not be affected. @Brogan can help. Upvote 0 Downvote
Tracy Perry Well-known member Sep 6, 2022 #8 Brogan said: It's a user group permission. View attachment 251953 If you want to set an avatar for each member, you can do so in the ACP. Click to expand... Revisiting this.. should the default avatar you set in the ACP not show in that same ACP users list instead of the text field? Upvote 0 Downvote
