Okay well , I have two plugins which basically do the same thing BUT each plugin has some missing , and the second plugin completes it.
Example:
Plugin A has Option A but misses B
Plugin B has Option B but misses A
Here is , what I think is needed to combine it:
Plugin A: http://pastebin.com/UZT1mXPb
Plugin B: http://pastebin.com/81FVrYus
Now what I need is those two combined. I want the user to login through plugin A , have it's variable stored using plugin A , then the same variable is used in Plugin B.
Needed from A: Login , the variable itself.
Needed from B:Everything besides the variable it uses.
Now I know this is kinda confusing and those may not be the files needed , but please I really need this done have nowhere to go.
Example:
