RichardKYA
Hello,
I'll start off by saying I am rubbish with js.
I am trying create an onclick popup div and after falling into a Google hole and being lost for about 12hrs, I think I have finally got things kinda working, BUT, the issue I am having is that the content of the popup relies on a variable that goes through a xen:foreach.
At the moment, I am trying to get the content from a div that has "display:none" via getElementById, but of course, the id is also subject to a variable that goes through the xen:foreach, example: id="item_{$user.user_id}".
So, a couple of questions:
1 - Is this the best way to do this?
2 - How can I pass xf variables in my js?
3 - Would it be possible to create the div and fetch the content at the same time instead of fetching it all first and hiding it with display:none? - Eg, instead of getElementById, just have content='{$example.content}' or something?
Here is an example of the code I have, I've changed the id and the getElementById to help explain what it is that I am trying to do, but like I say, I haven't a clue, so if this is not the way to go, I am very much open to suggestions
...my js...
Thank you for any help, I appreciate it
<xen:foreach>
<span onClick="myPopup();" class="more-button">More</span> // Once this is clicked
<div id="item_{$user.user_id}" style="display:none"> // This Pops up
<h3>{$var.name}</h3>
<h4>{$var.info}</h4>
<a href="link to page" class="view-page-link">View Page</a>
</div>
</xen:foreach>
...my js...
function myPop(){
// Creates a full width/height div as a "click-away" area to close popup
var close = document.createElement('div');
close.className = 'close-popup';
close.onclick = function (e) { close.parentNode.removeChild(close) };
// Creates popup div to contain content
var varInfo = document.createElement('div');
varInfo.className = 'info';
// Creates span inside popup to contain text fetched by id from display:none div
var infoText = document.createElement('span');
infoText.innerHTML = document.getElementById('item_{$user.user_id}').innerHTML;
varInfo.appendChild(infoText);
close.appendChild(varInfo);
document.body.appendChild(close);
