XF 2.0 I need help fixing my Iron on my site
Godzilla
The black one is mine. I changed something and I don't know how to fix it back to normal like another picture
.node .forumNodeInfo .nodeIcon,
.node .categoryForumNodeInfo .nodeIcon
@property "nodeIconForum";
background-image: url('@imagePath/xenforo/node-sprite.png');
background-repeat: no-repeat;
background-position: 0 0;
@property "/nodeIconForum";
.node .forumNodeInfo.unread .nodeIcon,
.node .categoryForumNodeInfo.unread .nodeIcon
@property "nodeIconForumUnread";
background-position: -36px 0;
@property "/nodeIconForumUnread";
.node .pageNodeInfo .nodeIcon
@property "nodeIconPage";
background-position: -72px 0;
@property "/nodeIconPage";
.node .linkNodeInfo .nodeIcon
@property "nodeIconLink";
background-position: -108px 0;
@property "/nodeIconLink";
/* FONT AWESOME NODE ICONS */
@font-face
font-family: 'FontAwesome';
src: url('./styles/default/xenforo/fonts/fontawesome-webfont.eot');
src: url('./styles/default/xenforo/fonts/fontawesome-webfont.ttf') format("truetype"),
url('./styles/default/xenforo/fonts/fontawesome-webfont.woff') format('woff'),
url('./styles/default/xenforo/fonts/fontawesome-webfont.eot?#iefix') format('embedded-opentype'),
url('./styles/default/xenforo/fonts/fontawesome-webfont.svg#fontawesome-webfont') format('svg');
font-style: normal;
font-weight: normal;
.node.node_51 .forumNodeInfo .nodeIcon:after, .node.node_51 .categoryForumNodeInfo .nodeIcon:after
font-family: "FontAwesome";
font-size: 34px;
content: "\f0e6";
padding: 4px;
.node.node_51 .forumNodeInfo.unread .nodeIcon:after, .node.node_51 .categoryForumNodeInfo.unread .nodeIcon:after
font-size: 34px;
content: "\f0e6";
padding: 4px;
.node.node_51 .pageNodeInfo .nodeIcon:after
font-size: 34px;
content: "\f0e6";
padding: 4px;
.node.node_51 .linkNodeInfo .nodeIcon:after
font-size: 34px;
content: "\f0e6";
padding: 4px;
View attachment 171947View attachment 171946
If you have not made any other customisation other than node icons.
Remove all extra.less code and save it as blank.
Then add code one by one and save and refresh page to see effect.
Proceed till you again go black, that moment will gove you clue what wrong in that extra.less attributes
I just want to make it back to default
I did as you said it's still the same
Extra.less has nothing to do with original code.
Its a blank file and it is provided to have custom modification code in it for css.
If you do not have any modification made to your site in any aspect for themes.
Then go to admin cp
Then appearance
Then template
Then look for templates with red color and click on them to revert to original.
Or create new child style and shift all user to that style and delete this faulty style.
Just play around appearnce tab, you will get more details
For background color of node
.block.block--category.block--category(x) .block-header {
    background: #52c036;
    color: #ffffff;
For Material Design Icon for nodes
.node--forum.node--id(x).node--read .node-icon i::before {
  font: Material Design Icons;
    content: "\f186";
    color:     #d62d20;
    opacity: 0.3;}
.node--forum.node--id(x).node--unread .node-icon i::before {
    content: "\f186";
    color:     #d62d20;
Do change (x). With your node and category id.
color: #ffffff;
content: "\f186";
color: #d62d20;
opacity: 0.3;}
content: "\f186";
color: #d62d20;
how do you find category id.
